3802 and Video Switching
johndj1
Have a standard Sky box (RGB Scart out), Denon 3802 and Plasma with Composite input (currently used for input from STB), S-Vid (currently used by DVD), and three spare Component Inputs.
My ideal world is to run an output from the STB to the amp and then from component out on the amp to component in on the plasma.
The queries are:
Can I input to the amp via composite and then out via component?
If so, as the only component is Monitor, will it also take the signal from the STB?
If not, can anyone suggest a way I can dramatically improve the pic from my STB to the TV (prefereably with Vid switching.
Dan
Dan
Reiner
No, there is no such conversion in this model.
I rekon the following, given that the equipment has the matching outputs:
STB via S-Video
DVD via Component
Else you might consider buying an adapter (S-Video / RGB to Component).
Podcast: Best Home Cinema Sources and B&W 805 D4 Speaker Review and more...
