3802 and sub settings
Discussion in 'AV Receivers & Amplifiers' started by john R1, Jun 19, 2004.
  1. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    have been listerning to some dvd-a via 6 x phono connections everthing works ok on multi-channel, but when i play something like a cd i.e. in stereo cant get any signal through the sub have checked settings on my dvd sub is selected e.t.c. if i play cd via digital coaxial lead sub works fine is there any settings i dont know about on the 3802
  2. Ian J
    Ian J
    Aug 6, 2001
    25,529
    +4,906
    When listening to a DVDA (or SACD) all of the processing is done within the player and the results are output to the amp via the 6 channel analogue phono outputs. Any bass management facilities have to be set within the DVD player but they tend to be rudimentary at best
  3. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    Have checked all the settings on my dv89 everything is set up for the sub, but cant get any sound out from the test tone page, yet when using 6 channel audio sub works fine, perhaps there is a problem with my dv89
