3802 and dvd-audio
Discussion in 'AV Receivers & Amplifiers' started by john R1, Apr 13, 2004.
  1. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    Has the denon 3802 the inputs for connecting up a dvd audio player
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,533
    Rainham Essex
    +2,517
    Yes, it has the 5.1 analogue inputs required for either DVD-A or SACD. But it only has the 1 set, so you can't connect both unless you have a player that can do both.
    Mark.
  3. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    am purchasing a dv89 so sacd is of no interest to me thanks for the reply
  4. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    Having looked in the 3802 booklet there seems to be 8 seperate inputs for dvd-audio do i need to run phono leads to the sub input as well as the rest i.e. front centre etc, am getting confused i thought i only needed 3 phono leads but this adds up to 4 pairs of leads
  5. Supra
    Supra
    Dec 12, 2002
    433
    Kent
    +14
    I would say a defiante yes, not an expert on these things, but I think the processing for dvd audio would be done in the dvd audio player.
    I know you do on my amp.
  6. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    DVD-A is 5.1 so you need 3 pairs of cables including a sub lead, if you have a sub, ignore if you don't. The other two are probably for centre back channels in a 7.1 system. The 7.1 input is not just for SACD and DVD-A, it's the kind of future proof the system. I mean if somebody anounces DVD-A v2 tomorrow that is 7.1 and not 5.1, you would be ready to use it.
    If you have no sub, just use the 2 mains, 2 surrounds and centre, so 5 single phono cables in all.
  7. john R1
    john R1
    Nov 2, 2002
    692
    16
    essex
    Cheers stereo steve am running one rear centre at the moment might as well ignore that for the dvd-audio am running sub also so should just need 3 x phono leads
  8. Stereo Steve
    Stereo Steve
    Jul 11, 2003
    1,939
    38
    UK
    +7
    Yep, just 3 will do. Remember though that as it's an analogue bypass you need to set up bass management and speaker distances/ levels on the DVD player too.
