3802 alternatives?
Discussion in 'AV Receivers & Amplifiers' started by Zone, Dec 11, 2001.
  1. Zone
    Zone
    Jun 24, 2001
    6,813
    Barnsley
    +2,573
    Lot of talk re 3802 but are there any decent alternatives of comparable quality and spec, thinking primarily of the Marantz lines SR6200 and 7200, anyone have any experience of these or any other (lets face it) cheaper alernatives?
    cheers
    Si
  2. Guest
    An alternative, but not cheaper is the Onkyo TXDS-696. Retail prices are about the same but I couldn't find the Onkyo cheaper anywhere. Has everything you could want including component switching and great learning remote. I have this in a set-up with KEF Q55.2 front speakers, Q95c centre, Mission M7DS surrounds, Toshiba SD210E DVD player and Arcam CD72. The sound is phenominal and the build quality of the Onkyo is second to none. Just turn the volume dial and you'll see what I mean! I'm told it's slightly more musical in stereo than the Denon as well but I don't think there's very much in it.
    Highly recommended, especially if you don't want to tag along with the rest of the Denon crowd. Have an audition. Your musical tastes might be different from mine.
  3. jspone
    jspone
    Dec 5, 2000
    89
    Lancs
    how about the 2802 ?
  4. Lowrider
    Lowrider
    Or the Onkyo 595, or the Marantz 5200... it´s your money and your ears...
    It dependes on your budget, speakers and path to upgrade...
  5. sraper
    sraper
    Aug 7, 2001
    825
    Watford, UK
    +268
    Or in my case dearer alternatives :devil:
    I like the sound of the denon AVC-A11SR but it is VERY expensive. By all accounts the 3802 is a nice piece of kit, but it is not THX and it doesnt have the tuner meaning I would have to spend even more money on one of those. Ideally I would like the A11SR but for only £1000 or so!
    Stuart
  6. dochall
    dochall
    Not THX but it does have a tuner.
  7. Lowrider
    Lowrider
    The Onkyo 797 is THX and has a tunner...
  8. sraper
    sraper
    Aug 7, 2001
    825
    Watford, UK
    +268
    oops. What I meant to say was that the 3802 has the tuner but no THX, whilst the A11SR is the other way around but around £1000 dearer.
    Why cant Denon produce a model in between these two. Say for £1200 RRP
  9. WSC
    WSC
    Nov 1, 2001
    60
    Going back to the original question. It depends on what you actually want / need.
    I have just ordered the Marantz 5200. I wanted a reasonably priced amp that was good for music and movies and had good functionality. I tested the Yamaha 620, Denon 1802 and Marantz 5200. I liked the Denon and Marantz best. I have a Marantz 4100 DVD and the Marantz had little features like 7 channel input and 6.1 DD/DTS (neither of which I am likely to use).
    I could not justify an extra 300+ on a Denon 3802 (plus all the additional quality equipment to go with it).
    The Marantz 5200 can be got for ~350. By the way the Marantz 6200 remote is just awful - not just bad like all the other ones people slag off.
    At the end of the day only you can decide by listening to them.
