3802/a85 connections ???
Discussion in 'AV Receivers & Amplifiers' started by wakko, Aug 30, 2003.
  1. wakko
    wakko
    So...it goes like this,
    I want to connect the A85 to the 3802, using the A85 to drive the front L/R....problem is....I've connected the pre outs (L/R) of the 3802 to the TAPE IN on the A85, then selected the source on the 3802 i.e....SKY (for which I get centre, surround L/R), selected TAPE on the A85... but still cant hear anything....can someone please help, its driving me to distraction, am I missing something obvious ?????
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,446
    Aldershot, Hampshire
    +267
    Have you got the front left and right speakers connected to the a85?
    Have you depressed the av processing button for more than two secs- a light below the tape light should come on.
  3. wakko
    wakko
    strangerer and strangerer.....it started working....mind in boggle mode, though I have a sneaking suspicion that I inadvertently depressed the tape/proc button for more than two secs, prob out of sheer frustration.....Dark forces at work methinks, thanks hawklord
  4. Hawklord
    Hawklord
    Feb 15, 2003
    3,446
    +267
    glad to help.
