3802 A+B speaker setup
Discussion in 'AV Receivers & Amplifiers' started by deang, Mar 7, 2002.
  1. deang
    deang
    The Denon 3802 has surround speaker capability for A, B, and back. Reading the manual, it suggests that you can use the "B's" for 5 channel music (i.e. monopolar), leaving the "A's" plus rears for the 7 channel (recommending bi/dipolars).
    It seems as though it's possible to select both A + B speakers, so does that mean it's OK to have both A and B as surround sides, and surround rears for movies? (Giving a max total of 9 speakers plus a sub).
    Does the sound processing 'work' like this, and will the amp take the total speaker impedance?
    Any thoughts?
  2. Jase
    Jase
    Mar 16, 2001
    10,723
    United Kingdom
    +2,496
    The amp will let you run both A & B at the same time, but it can bugger up the surround effects and depending on your speaker impedance could cause the amp problems.
    I have tried this but wouldnt recommend it to be honest.
    Its best to stick to surround A for Movies (dipoles/bipoles etc) and Surround B for Music (monopoles) and you can still run your surround backs with either if you want to.
