3801 remote code for Sony projector
Discussion in 'Home Cinema Control & Remote Controls' started by mikeaitch, Feb 24, 2002.
  1. mikeaitch
    mikeaitch
    Apr 21, 2001
    1,608
    Stoke
    +56
    I'm having trouble teaching my learning remote from the Denon 3801 any commands for my Sony VPLHS1 projector.
    The remote doesn't have a button really suited to using for a projector, so I've used the VDP one and tried to use the learn function. Trouble is, although it says OK when I teach it, none of the 'learned' functions actually work.
    Does anyone have the 4 number code for this projector? Or am I doing something wrong?
    Any help would be appreciated
