3801 and laserdisc player
Discussion in 'AV Receivers & Amplifiers' started by The Sheriff, Feb 6, 2003.
  1. The Sheriff
    The Sheriff
    Jan 2, 2003
    449
    Goch, Germany
    +6
    simple question:
    can i get dolby digital out of a laserdisc player using the denon 3801
  2. Sick Note
    Sick Note
    Nov 8, 2000
    451
    +26
    Hey Richard :hiya:
    What you need to get yourself is a an RF demodulator.This little box takes the RF DD output from your laserdisc and converts it to a standard coax digital output which you can then feed to any of your digital inputs on your amp. I know Kenwood,Yamaha and a couple of other companies made these, not sure if they still do. Ebay is probably your best bet. Good luck and good hunting.:smashin:
