37WLT58 v 32PF9830
Discussion in 'LCD & LED LCD TVs Forum' started by Peritas, Oct 27, 2005.
Tags:
  1. Peritas
    Peritas
    I've just come back from my local TV shop. I originally went to buy a 32PF9830, but was drawn to the 37WLT58, I'd never even heard of this set and can't see any reviews on it.
    Is it worth getting over the Phillips? I was drawn to its a bigger picture, the stand and has 2 HDMI connectors.
    But I'm guessing the 32PF9830 has a better picture?
    Any advise would be nice, cause I left the shop without any tele. :(
  2. richard plumb
    richard plumb
    Jan 27, 2002
    14,555
    Windsor
    +1,057
    I wouldn't assume the 9830 has a better picture just because its more expensive. Possibly it might look better to you, but I think many of the premium sets are pretty close these days. Maybe they vary in terms of how well they clean up current SD TV - my philips was always pretty good at that with pixel plus
    I'd go and try and see both in action with good sources - take along a favourite DVD. Also try one with THX optimiser on it and see if they'll let you have a little tweak of each set, just to get a slightly more level playing field.
  3. Peritas
    Peritas
    Thanks for your reply. The main reason I'm interested in the 9830 is becaue of the What Hi-Fi TV on the year award, that write up makes it sound like the perfect set lol.
  4. richard plumb
    richard plumb
    Jan 27, 2002
    14,555
    Windsor
    +1,057
    there isn't such a thing as a perfect set unfortunately
    the 9830 does appear to be a very very good one.
    For me it was simply too big. And as most sets seem pretty close these days (at least the ones I was considering), that was enough to rule it out.
    2xHDMI was the killer blow for me on the Toshiba I finally bought. Just enough for SkyHD and PS3/bluray. and no need for an expensive switcher (although I will need a component switcher)
  5. Peritas
    Peritas
    So you got the 37"? and you sound happy.
    I think the Tosh will just sit better in my room with the intergrated stand. I pushing the size of the screen with my room not being that big. If I'm lucky and if the set fits in the right corner I can get nearly 3 Metres away from it...
    Every one else in the family will have ti suffer lol.
