37WLT58 issue with PC
A
aatish
i just bought this tv from my brother to use it as a TV and PC monitor
i have connected my pc which runs XP with HDMI not VGA
but now i have a problem.
i left the pc on and turned the LCD off to go to the shop for some milk.
when i got back, i had a black screen, i thought it might be the screensaver, so i moved the mouse pressed the keyboard nothing happed. so i had to restart the pc and it worked.
then i looked a bit deeper, and pressed the AV button to switch to telly, then back to HDMI and the screen went black again, in a matter of 20 second.
anyone know whats goin on, as i dont want to keep restarting the PC
please help
Dankeech
please help
It's quite likely your TV has a setting for power management that is currently set to dim/power off etc if on an AV input with no movement (ie windows desktop wallpaper etc).
Have a look in power management menu and see if there's any auto-off options etc.
Sorry, I don't have a Toshiba TV myself to check against.
Dan.
