37WLT58 - hidden feature ???
Discussion in 'LCD & LED LCD TVs Forum' started by bs_lcd, Mar 26, 2006.
Tags:
  1. bs_lcd
    bs_lcd
    Mar 26, 2006
    26
    3
    +6
    Apologies if this has been previously mentioned ..
    To go through each input source - i have had to press the 'Input Selection' button once at a time.
    But just noticed that if you keep the 'Input Selection' button pressed down - a menu appears with all inputs - can then use arrow keys and select with 'ok'
    Has this feature always been there ?? (cannot see it in the manual)
  2. Tempest
    Tempest
    Jan 11, 2002
    8,500
    Horley, Surrey
    +4,150
    Yup, been there ever since I had my set :)
  3. DaveP
    DaveP
    There are so many inputs on these it was a pleasure to discover this feature on my 42" set.
    Discovered by accident!
  4. jeallen01
    jeallen01
    Nov 24, 2005
    341
    28
    +70
    Ditto on my 32" set, and you need it - otherwise you have to tediously select one input after another!
  5. wandersen
    wandersen
    Nov 28, 2005
    521
    +12
    Or even easier - you just push the OK button when watching TV and it provides you with the selection.
  6. Tempest
    Tempest
    Jan 11, 2002
    8,500
    Horley, Surrey
    +4,150
    Ohhh, never knew that. Will try it later :)
  7. SRR
    SRR
    Dec 14, 2005
    196
    +87
    Page 10 , No 4 of instruction manual for input button info (although I don't see the analogue channels as in picture.)
    But I did find this that is not in the manual, AFAIK.
    press the "Guide" button to call up EPG, then press the "Menu" button. You can now flick through a now & next guide while watching the channel you are watching.
    Any others people have found ?.
