37wl56 + free dvd for £1380!?
Discussion in 'LCD & LED LCD TVs Forum' started by mickbarlow, May 10, 2005.
Tags:
  1. mickbarlow
    mickbarlow
    Dec 1, 2004
    532
    +7
  2. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    Are these specs correct? 15:9? is this an old panel?
    Toshiba 37" WXGA LCD Widescreen Television
    Resolution – WXGA 1280 x 720
    Active Vision LCD Picture Processing
    Real Digital Picture Processing
    Brightness – 500cd/m2
    Contrast – 600:1
    Viewing Angle – 170 degrees (Vertical & Horizontally)
    HDMI x 1
    SCART x 2
    Composite x 1
    Audio Output – SRS WOW 20W
    Cabinet Stand Supplied
    I suspect the price is correct, the new Samsung 40" is advertised @ £1699, trouble is everything seems to be on pre-order, where's the stock?
  3. mickbarlow
    mickbarlow
    Dec 1, 2004
    532
    +7
    ive emailed them to find out what the story is, sommit aint right surley?
    the 32" version is pretty cheap too, http://www.be-direct.co.uk/productDetails.asp?id=17411
  4. neilmcl
    neilmcl
    Oct 29, 2004
    6,236
    103
    Nottingham
    +292
    Where does it say it's a 15:9 panel? Do the maths, 1280x720 is a native 16:9 ratio.
  5. SPGupta
    SPGupta
    It seems TVandVideoDirect are currently offering this item at £1425. It sounds like a good price! I checked Toshiba UK site. The resolution is officially stated as 1366x768. But, no PiP!!
    Can someone suggest a similar spec. 37" LCD TV with PiP? I know Philips 37PF9986 @ £2235 is a full Dual Screen but the price differential id £810. Is it worth the extra? I would like to hear from any one.
  6. snoods
    snoods
    Apr 26, 2005
    303
    Kilwinning, North Ayrshire, Scotland, UK.
    +64
  7. Taz69
    Taz69
    Apr 15, 2002
    3,403
    Bristol
    +343
    Exactly, 1280x720 is true 720p no scaling etc, think you are mistaken with 1280x768 that makes it a 15:9 panel.
    Taz
  8. Taz69
    Taz69
    Apr 15, 2002
    3,403
    Bristol
    +343
    also they have put the price up already to £1429.99
    Taz
  9. blackjane
    blackjane
    Jun 6, 2005
    16
    The price has gone up, but it still appears to be the best deal out there for this screen.
    However, stock might be a different issue!
    I convinced a friend to plump for one from BE-Direct, but they're now quoting 2-3 weeks for delivery (even though there was no such suggestion at the point of order.)
  10. SPGupta
    SPGupta
    Hi Snoods,
    1499 at Currys & Dixons. Is it Toshiba 37WL56 or something else? Any ideas on the 37" LCD PiP? Philips 37PF9986 is rather expensive at 2235!
  11. snoods
    snoods
    Apr 26, 2005
    303
    +64
