say if i got one of these from jl would it fit on a 37pe50 stand so i wouldnt have to purchase a ped and would they sell it if priced matched with someone
without ped
thanks culp
I'm pretty sure that since the PE50 range turned into the PX60 range, the actual fittings on the pedestal were at slightly different distances & therefor didn't fit. The PX70 range is based on the PX60 - they're identical in fittings to both pedestal / cabinet & wall bracket, so I'm pretty certain your answer is "no".
You'll have to get the latest pedestal to fit the PX70.
