37PW7 Cabling.....HELP!
Discussion in 'Plasma TVs Forum' started by PannyAdams, Dec 16, 2004.
  1. PannyAdams
    PannyAdams
    Dec 5, 2004
    669
    Epsom
    +5
    Ok....I know we've been here before. But I've had a brain wave will this work.
    Current Plan:
    VGA -> Media PC
    Scart -> SKY+ (RGB) + PS2 (Composite) chained
    HDMI -> DVD
    Brain Wave:
    VGA -> Through JS Box -> SKY+ (RGB) + PS2 (Composite) chained
    DVI -> Media PC
    HDMI -> DVD
    Will this give me the best possible picture for all my devices?
    Have I learned well from the Horny Dragon? :lesson:
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    YES BUT the JS box as it is affectionatly known is RGB (only) to VGA buy an RGB cable for PS2 £10 and then it will work and work well...........
  3. PannyAdams
    PannyAdams
    Dec 5, 2004
    669
    Epsom
    +5
    Cool.
    Is the PSX cable a Sony pheriperal......do I have to set any options in the PS2?
    Also, with it daisy chained, how do I get the PS2 picture....just turn the PS2 on and sky off?
    Am I right in assuming that the JS RGB solution is noticably better than the Panny Scart?
    What is your comment about PIP? Can you not get PIP sources from the VGA port?
    BJ
  4. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
  5. PannyAdams
    PannyAdams
    Dec 5, 2004
    669
    Epsom
    +5
    No 50 hz support...........Arrrrrrgh!
  6. PannyAdams
    PannyAdams
    Dec 5, 2004
    669
    Epsom
    +5
    OK......I just been and read the end of the HDMI thread. And I know this is cutains from SKY HD point of view, but what about getting the best picture from a DVD?
    Does this mean that it will play Region 1 discs fine, but have problems with PAL discs? Or will is handle both at a lower resolution?
    Should I still be holding out for digital DVD to Panel or is it now a no go with Progressive Scan to Component being the best format on offer?
    Will the HDMI card offer anything that the DVI card doesn't?
    I'm ever so confused!
