PannyAdams
I have hooked up my PC (Running Windows XP Pro) to my 37" PW7 via the DVI. The monitor just shows up as a Plug and Play monitior and has a set of standard windows resolutions. If I drop the resolution down to 800x600 it is quite resonable.
I remember reading a post by LisaG who has the same screen saying she plugged in Windows MCE and it recognised the screen and drove it at the native res (856x560?).
As MCE is just XP with a s****y front end, are their any drivers that I can plug in to get the display better?
Also, is it worth upgrading a partition to Windows MCE 2005? Will it work with my ATi 9200 SE card?
Help!
Panny
Help!
Panny
