37PV500CAB Owners - Help required
Discussion in 'Plasma TVs' started by Yousanem, Jun 8, 2005.
  1. Yousanem
    Yousanem
    Got my order in with AV Sales for a 37PV500CAB :thumbsup:
    Trouble is, delivery is not going to be for two weeks :thumbsdow
    I'm itching to get going with my new home cinema set up, but the problem is that space is tight and the speakers and receiver I get have to fit on and around the cabinet stand. So if any of you have one of these babies and have possession of a tape measure, can you please post the info so I can get the rest of the kit and keep my mind off the wait? Here's what I need...
    >Height of base of stand off the floor (for speaker stand proximity).
    >Front to back measurement of stand at the ends.
    >Total height of screen plus stand.
    >Available height of each shelf and range for movable shelf.
    >Interconnect length using cabinet channels from bottom shelf to screen inputs.
    Thanks for your help - I'll post photos when it's all set up :hiya:
  2. cwatson
    cwatson
    TH37-PV500B
    Stand Total Width 104cm, Opening width 68cm (i.e. The total width for all your AV equipment per shelf)
    There are 3 shelf positions, from the bottom up:
    1st shelf can be positioned at 15cm or 20cm
    2nd shelf is 28.5cm from the base and is 13cm from the top
    My configuration is base shelf 20cm, 8.5cm middle opening, whichs leaves 13cm for the top shelf space.
    The top shelf is 32cm deep, the middle is 35 and the base is 49cm deep.
    Note: the fittings below the two removable shelves *can* decrease the depth of the shelves. In my case my 6.5cm high DVD, hits this mount so only goes back 25 or the available 35cm's
  3. Yousanem
    Yousanem
    :smashin: Hey, thanks C! Just what I needed to hear.
  4. RobbieTT
    RobbieTT
    Jan 9, 2005
    398
    +7
    Fantastic post! Everything I need and a picture too.
    Hope I'm doing the right thing...
