37pf9986 viewing distance
Discussion in 'LCD & LED LCD TVs' started by halsia, Apr 5, 2005.
  1. halsia
    halsia
    I will be watching sky (and possibly sky hdtv whenever that comes along) and
    dvds.
    What's the optimum viewing distance for the 37pf9986?
    thx
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Absolute Minimum 8 feet. Optimum 10 - 14 feet.
    Jimmy
  3. Alan D
    Alan D
    Jimsan is pretty much spot on - in my case I sit 9 feet away from it and it looks great for almost all viewing especially DVD through DVI-DVI. Sometimes slight pixellation is noticable on Sky (depending on the channel) - but this is really a Sky problem not a TV problem. I am really glad I went for the 37" rather than the 32", especially for movies - bear in mind that the majority of movies are shot in 2.35:1 aspect ratio - so you get a letterbox picture even on a widescreen TV - so having those extra 5" of screen size really makes a difference!
