37pf9986 problem
Discussion in 'LCD & LED LCD TVs' started by csuraci, Apr 5, 2005.
  1. csuraci
    csuraci
    Hi to all
    I bought a philips 37pf9986 tv and i received it today.
    First 2 hours ok, perfect..then i noticed a noise when ambilight is on...is it the famous ambilight buzz? when i turn off ambilight it disappears..
    how could i resolve / reduce this problem.
    my firmware is 2.0
    thanks , please help me soon, i don't know if i should return it to my dealer...
  2. Phill_1981
    Phill_1981
    Feb 14, 2005
    1,532
    Woking, Surrey
    +44
    I think you'll find it's normal.
  3. Rob1698
    Rob1698
    All sets have a faint buzz when ambilight is on.
    Compared to the rattle from a similar-sized CRT TV it should be very weak.
    When you hear it when seated, with the audio on, you could consider complaining.
    But when you only hear it standing next to the set, without audio, there is little to worry about.
  4. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Go into the Ambilight settings and set it to 'relaxed' (I think) This setting is less intense and allows it to run quieter.
    Jimmy
