37pf9986 and US Xbox
Discussion in 'LCD & LED LCD TVs Forum' started by Warp, Feb 12, 2005.
Tags:
  1. Warp
    Warp
    Jan 5, 2005
    69
    I am trying to connect my US Xbox with component cable via the adaptors to the DVI port. However all I get is the message "Picture format not available".
    Can anyone help?
  2. jimsan
    jimsan
    Oct 8, 2004
    1,610
    41
    Dumfries, SW Scotland.
    +9
    Do you have a facility to output in Progressive Scan on your Xbox. The 9986 will only display Progressive pictures.
    Jimmy
  3. Warp
    Warp
    Jan 5, 2005
    69
    Yes. It can output at 480p, 720p and 1080i. I have Firmware 2.1 so not sure why it cannot read signal. Will call Philips on Monday.
  4. Rob1698
    Rob1698
    I have connected a normal PC via VGA cable and it works OK at 720p and 1080i.
    (and also the advertised PC resolutions)
    So the table in the manual is a bit misleading. One could think that in VGA (RGBHV) mode only the 640x480 800x600 and 1024x768 PC resolutions are valid, and for the HDTV resolutions one needs to supply component video.
    But this is not true, the TV can handle 720p and 1080i in RGBHV mode. I don't know about DVI-D, not tried yet.
    So when the X-BOX has a VGA output (don't know if it does) you can try a plain VGA cable.
  5. genoa1893
    genoa1893
    Nov 16, 2004
    142
    +4
    I'm very interested....i'm thinking to buy a 42" version..but if cannot accept PS from consoles, i'll go for something different.(Loewe or Sharp).
    Ciao
