37PF9986 and Component
Discussion in 'LCD & LED LCD TVs Forum' started by zerolight, May 17, 2005.
Tags:
  1. zerolight
    zerolight
    Jan 29, 2004
    239
    Glasgow
    +9
    I'm thinking of changing my order from a TH42PV500 plasma to a 37PF9986 LCD. I've read folk having problems connecting component into their 32PF9986 and that the required adaptors were also missing. Though I see that this has been mostly resolved via software updates.
    Can anyone tell me if the same problem plagues the 37" model too, or hasa everyone recieved the adaptor cables and been able to connect component sources without problem. Does it only accept progressive component, and will it take RGB component too?
    Thanks,
    Graham.
  2. steeled
    steeled
    Apr 23, 2002
    485
    28
    Maidenhead
    +54
    I bought the 37PF9986 about a month ago and received the correct firmware and cables to connect component. It worked without any problem.
    HTH
    Dave
  3. zerolight
    zerolight
    Jan 29, 2004
    239
    Glasgow
    +9
    Cheers.
    Did you go for the tabletop stand or did you wallmount it. ?
    Graham.
  4. steeled
    steeled
    Apr 23, 2002
    485
    28
    Maidenhead
    +54
    Hi Graham
    I use the desktop stand at the moment. I do not want to drill big holes in the wall at the moment.
    As standard you only get the wall bracket. You have to pay extra for the stand. When I bought mine they were offering a free DVD Recorder - I perusaded them to drop the DVD recorder (I have a PVR) and give me the stand for free.
    The desktop stand is quite wide (around 1000mm) as it is also intended for the 42" screens as well.
    I failed to mention in my previous post that the included component lead is not very long. It is fine if you install your DVD player below the TV but if your DVD player is some distance away you will need a longer cable. I purchased a 3 phono to VGA cable from lektropacks.co.uk.
    Cheer
    Dave
