37pf9986 ambilight buzz
Discussion in 'LCD & LED LCD TVs Forum' started by Warp, Feb 25, 2005.
Tags:
  1. Warp
    Warp
    Jan 5, 2005
    69
    Has anyone got a 37pf9986 where that cannot hear the ambilight buzz from 3 metres away when the sounds is off? I think I may just have sensitive hearing.
  2. lz1cam
    lz1cam
    Hello,
    It is not only your ears but mine too... I really can hear the backlight system inverter duty cycle tone, plus the constant whistle of the power supply :-(
    I guess we have to live with that ...
  3. Alan D
    Alan D
    My 37PF9986 Ambilight buzzes ("tizzes"?), but it's not too bad at my 2.7 metres viewing distance - and different settings of Ambilight produce different levels of buzz - so worth trying to minimise it by playing with the settings. For some reason maximum saturation red (palette and saturation both at "full") makes the least buzz on mine, although I prefer yellow!!
    Usually, with normal listening volumes, I forget about the buzz after a while (and, I too have fairly sensitive hearing). At least there's no "contrast" buzz!
  4. rundmc51
    rundmc51
    there is a mod that philips can do to reduce the noise. it is a known problem with the 9986 tvs, get in touch with philips
  5. Warp
    Warp
    Jan 5, 2005
    69
    Phoned Philips..........they didn't know of any mod to reduce ambilight tizz noise level. Can you provide any more details?
  6. Tony B
    Tony B
    Oct 29, 2004
    557
    +21
    From ca 8ft, even with sound muted I cannot hear any buzz.
    If I get right next to the TV I can hear a slight buzz, but it is still less than the typical crt buzz you would expect from normal TVs.
    I don't think I have a problem with my hearing, either....
