37pf5520d and Sky+ = poor PQ?
Discussion in 'LCD & LED LCD TVs Forum' started by dravla, Oct 22, 2005.
Tags:
  1. dravla
    dravla
    Hi there,
    Just bought new Philips 37pf5520d and was very happy for few days watching Freeview through built-in digital receiver.
    Than subscribed to Sky+ and everything changed...
    Picture is grainy and there are shadows around all text, even Sky's. Footbal is even worse!
    Today got visited by a guy from Sky, who concluded the box's refresh rate is 50Hz, whereas TV is 100 Hz - hence all the problems!
    Is this possible???
    TV refresh rate can't be changed, I suppose (or at least I couldn't figure out how..)
    Anybody out there who could offer some advice ? TV setup? Scart cables?Any other input I should try (DVI,RGB)? :lease:
    I am thinking of cancelling Sky until HD is out...
  2. peahead
    peahead
    Dec 14, 2002
    3,252
    St.helens
    +564
    Hi dravla
    Sky a ***p at setting there boxes up and the refresh rate excuse is *******s you need to check which scart they have plugged sky into on your tv it should be ext-1 if not swap it next you need to enter the picture settings on the sky box and change the output to rgb you should see a improvement in picture.next you need to setup your tvs picture settings contrast,colour,brightness ect i used the thx optimode setup on starwars attack of the clones to adjust these settings.
    i would also suggest you change the scartlead for a better one dont spend more than than £30.
  3. dravla
    dravla
    thanks, mate
    I thought refresh rate story was rubbish. Ext 1 used and sky box is on RGB, any decent scart leads in mind?
    my Sky+ box is Thomson 80GB.
  4. peahead
    peahead
    Dec 14, 2002
    3,252
    St.helens
    +564
  5. scottwb
    scottwb
    Hi dravla,
    I also have this TV and Sky+. I have to say that the picture from Sky+ is excellent.
    My setup is:
    Sky+ scart (RGB) to QED scart/Component Video converter.
    I then take the Component Video into the DVI on the Phillips using the supplied component/VGA converter and VGA/DVI adaptor.
    The Philips input is then set to HD with Active Sensor switched on. I've also chosen the natural picture settings. Other than that I didn't change anything else.
    The scart lead is a good quality IXOS.
    Hope this helps.
    Scott
