37PE50 exiting from guide for no reason
Discussion in 'Plasma TVs Forum' started by GazH, Mar 14, 2006.
  1. GazH
    GazH
    Apr 17, 2004
    449
    On the corner of Wabash and Lake
    +77
    Hi all,
    Something strange started happening last night.
    At first what was happening was, when I went into the guide it brought the screen up and then exited immediately back to the channel I was originally watching.
    After a bit of playing around I realised that it would only exit if certain channels were on the guide. So, if I was watching channel 18 and went to the guide, the guide would remain on the screen. If I move down through the channels (in the guide) it would be OK until I got to channles 11 and then exit.
    If I went the other direction it would be OK till I got to channel 9 and then exit... very odd.
    It was OK (I think) last night until it found a new a new channel which was added... may be a coincidence, but thought I'd mention it anyway...
    I have tried doing a complete retune but this didn't help.
    Anyone else had this happen ??? is there an easy way to stop it doing it???
    Sorry about the long description....
    Many thanks in advance.
    Gaz
  2. GazH
    GazH
    Apr 17, 2004
    449
    +77
    Anyone ??? :lease:
  3. Orwella
    Orwella
    Oct 10, 2004
    750
    28
    Romford
    +31
    Remove all scarts and try again. If that fails, reset to factory defaults and try.
  4. GazH
    GazH
    Apr 17, 2004
    449
    +77
    Hi Orwella,
    Thanks for the advice.... As it happens I didn't get time to try anything last night but will give it a go tonight..
    Thanks again :smashin:
    Gaz
  5. GazH
    GazH
    Apr 17, 2004
    449
    +77
    The guide seems to have sorted itself out.... very strange..
    Gaz
