37" with same spec as Pioneer XDE
Discussion in 'Plasma TVs' started by brendan_dj, Feb 4, 2005.
  1. brendan_dj
    brendan_dj
    Feb 1, 2005
    1,293
    New Jersey, USA
    +99
    I really like the Pioneer 435XDE.
    1024x768 resolution which appears to be the highest around.
    HDMI connector as well as composite, 3xSCART (RGB) and PC(VGA) input.
    I like the idea that this is all in a seperate "media-box" with only one cable running up to the plasma (to be chased into the walls and hidden) This makes hooking up devices to a wall mounted version easier without trailing cables up to the plasma.
    The only negative point is the low contrast ratio of 1000:1, but surprisingly, does not cause a posterisation issue so perhaps it doesn't matter.
    However, It is a little TOO big. (Yes, there is such a thing)
    Will Pioneer ever launch a 37" version of this model? Alternatively can anybody suggest an alternitive 37" screen with similar spec?
    regards
    Brendan
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    sharp 37" LCD is closest you will get mate check out the 37" GD1E
  3. attach
    attach
    Eh the ration is 1200:1 and it really isnt that much of a problem (to me anyway)
