37" What to buy ??
Discussion in 'LCD & LED LCD TVs Forum' started by Fontie, Jul 2, 2005.
Tags:
  1. Fontie
    Fontie
    Dec 7, 2004
    196
    Yeading
    +11
    I'll be mainly watching Cable TV (TW) and DVD's whats a reasonable 37" LCD to get the only real must is excellent PQ and able to handle hi-def when it comes. The more im trying to read up on this the more confused im getting. What would you guys get ?
  2. DaveP
    DaveP
    What's your budget?
    Personally if I wanted 37" I would buy a plasma, not an LCD. This one
    Dave
  3. jimg
    jimg
    Jul 4, 2004
    826
    +58
    But the Panny has no hi-def input? i.e. DVI-HDCP or HDMI?
  4. DaveP
    DaveP
    One thing you can say about Unbeatable is they don't over whelm you with details!
    Try this link or if you want it from the horse's mouth: Panasonic
    Dave
  5. shoestring25
    shoestring25
    Feb 2, 2003
    3,893
    essex
    +434
  6. AndyX
    AndyX
    Aug 14, 2003
    87
    11
    Scotland
    +13
    If you want a 37" LCD TV now, the Toshiba looks good with bright pictures. I believe a 37" Toshiba with freeview is out shortly. For extra high resolutions check out the new Philips and JVC models. Sharp is possible but pricy- they do get good reviews.
    Personally I am weary of plasmas as expensive to fix if they go wrong and reflected in extended warrenies offered. Some companies seem to be quietly removing plasmas from their ranges as LCD panels get bigger. LCDs are not perfect as you will see elsewhere in this forum
