We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
37" PV500 Default Monitor
Discussion in 'Desktop & Laptop Computers Forum' started by ColdKilla, Nov 5, 2005.
  1. ColdKilla
    ColdKilla
    Jun 21, 2005
    727
    +19
    Should my PV500 be listed on my HTPC as default monitor or can I download a driver for windows XP for it and if so where?
    CK
  2. MikeTV
    MikeTV
    Feb 1, 2003
    7,782
    Ealing, London
    +842
    You won't be able to download a monitor driver for the PV500, but you might want to create one using powerstrip. But the only thing this will give you is the ability to configure different resolutions, which perhaps the default monitor doesn't normally support, and perhaps also specify some preferred colour temperature settings (although exactly what these settings should be is unclear). If the default monitor works for your desired resolution, there probably isn't much benefit in creating one.
