37" plasma - how far away?
Discussion in 'Plasma TVs Forum' started by davegtt, Jan 18, 2005.
  1. davegtt
    davegtt
    Dec 22, 2004
    112
    People, Im decorating the house in the next month and we'd love the plasma on the fireplace wall although the telly will only be moving about half a foot closer to the sofa but we're concerned the telly might be too close to us..... is there any guidelines as to how far away you should be etc. last thing I wanna do is decor the whole house and find the telly looks awful and unwatchable for a period of time etc....
    Dave
  2. nic@highgroundd
    nic@highgroundd
    Jan 10, 2005
    182
    +3
  3. Tejstar
    Tejstar
    Dec 4, 2002
    22,740
    London
    +1,075
    I have a 37" plasma and still roughly 10 feet away!
  4. Skunky Cubes
    Skunky Cubes
    I watch either a 83" projector picture or a 36" CRT TV from about 10 feet away and I wouldn't say either is bad. In fact the 83" looks fantastic. We looked at a plasma and was concerned like you about screen size. Screen size is certainly more of an issue with plasma because of their relative picture quality.
  5. davegtt
    davegtt
    Dec 22, 2004
    112
    thanks for the tips. due to the width of the room and the lay out we cant use the length of the room so we'd be sat approx 7-8ft away from the telly which seems a tad close....
  6. peezee
    peezee
    I have about the same distance from screen and buying a 37" plasma. It depends a lot on the plasma but also from the source, but in general 7-8ft should be fine for a 37" screen, 32" really is too small.
    Don't forget also that the vertical size of the picture on a 37" 16:9 screen is about the same than on a mere... 30" 4:3 display :eek:, not to mention the horizontal black bars when watching 2.35:1 movies and the like... So pretty soon you find you that 37" for a 16:9 display don't amount to such a huge picture in the end... ;)
  7. edinburgh160
    edinburgh160
    I sit about 2 metres away from my 42" plasma and have no problem with this, although it depends on your source material if this will be ok. On Hi-Def DVD's even closer is fine. Some SKY channels quality is questionable, but again this is the source.
    I did test it out with the plasma I bought because I was thinking of the 37" and I'm glad I bought the 42" now.
    Maybe you should go to a shop and stand the required distance away to see what your comfortable with.
    If you are using SKY and DVD then make sure you are watching a screen using these and not a screen showing crappy analogue,
    cheers
  8. davegtt
    davegtt
    Dec 22, 2004
    112
    sorry, should explain better. we already have the telly. its the 37" Panasonic Viera. when we originally got it after an hour of viewing our eyes were killing. we managed to get it a further 2 feet away and its much better :) now its gonna come back an extra foot towards us if we mount it on the wall..... unsure of how its gonna be
  9. markevo
    markevo
    Aug 19, 2004
    32
    liverpool
    I have a 42" panny and sit about 9ft away and its spot on, its not as big as you think, it takes about 3 or 4 days to get use to it then you wish you got the 50" haha.
  10. edinburgh160
    edinburgh160
    yep, it's amazing how used to it you get.
    what's your set up. If ur using RGB scart for SKY and at least component for DVD then I would say 2 metres would be fine (sorry I'm a metric person )
  11. davegtt
    davegtt
    Dec 22, 2004
    112
    using RGB scart for the NTL box yes and the DVD is run off scart too but the DVD gives better quality than the NTL box so this sounds like it might be OK then :) thanks for the help guys, mucho appriciated
  12. sunil1234
    sunil1234
    Dec 5, 2004
    1,328
    48
    +121
    I have the 37" panny and we sit 6ft away, its fine!
    S
