37 Panny
Discussion in 'Plasma TVs Forum' started by novice2, Jan 21, 2005.
  1. novice2
    novice2
    Does anyone know if I can connect my dvd player using component and my dvdr using RGB in AV4 ie split the AV4 connections on the above.....
    I have it all set up but still can't get rid of the feeling its not set up in the best possible way!...
    As always, help gratefully received...
  2. GalacticaActual
    GalacticaActual
    Jun 1, 2004
    5,866
    Galactica C.I.C.
    +279
    Yep should not be a problem, although you wont get sound from the one connected to the componenet inputs. The blue button on the remote will allow you to switch between the inputs, but the rgb may override the componenet one if both are on together.
  3. novice2
    novice2
    Excellent
    Thanks for the help. This will mean I can get RGB for SKY+ and the DVD recorder, watch SKY without having to daissy chain it through the dvdr and keep component for the dedicated DVD player with sound coming through the coaxial connection to the amp. Many thanks :clap:
