37" or 42"? Which size is best value?
Discussion in 'Plasma TVs Forum' started by dave owen, Oct 26, 2005.
  1. dave owen
    dave owen
    Dec 8, 2002
    72
    Getting a PE50 but am hesitating on which size. For the price difference 42" looks a better buy but at a viewing distance of 9" could be to overbearing in the room. But don't want to get a 37" and wish I'd got a 42".
    Anyone regretted the size they bought?
  2. Tejstar
    Tejstar
    Dec 4, 2002
    23,034
    London
    +1,157
    Well I sit at just over 10 feet and think a 37" is fine. Although if it was wall mounted I'd probably move for a 42".
  3. Jazz Monkey Jr
    Jazz Monkey Jr
    Jan 10, 2005
    14,359
    2
    4
    137
    Garstang, Lancs
    +1,633
    Pound for pound, 42" is the best value - as long as you have room for it.
  4. Rahmorak
    Rahmorak
    Nov 30, 2004
    452
    Lake District
    +10
    I'm not really sure picking a panel-size based on best value is the best way to do it.
    Personally if you can afford it I would go for the biggest size you can get within reason, and at 9' a 42" should be fine. (I run a 50" at 12-13' but can sit closer without any problems)
  5. RHCP
    RHCP
    Jul 31, 2005
    1,313
    Liverpool
    +25
    Get the 42" mate, you won't regret it!
    You might (probably will) regret it if you get a 37".
    My viewing distance is between 9' and 10', looks exactly right for the distance! :)
  6. Lionheart
    Lionheart
    I think the 42incher is just perfect for most living rooms....if u r about 10ft away its spot on
  7. Fossil
    Fossil
    May 29, 2005
    105
    +5
    I bought a 37" (the wife wouldn't entertain anything bigger) and wall mounted it. While we are both blown away with how good it is I soooooo wish we had got the 42".
    Its a funny thing, both me and the wife thought it looked pretty big out the box but once wall mounted it don't look so big anymore.
    Get the 42", you'll enjoy it more.
  8. acrmorris
    acrmorris
    Jul 5, 2005
    326
    16
    East Grinstead
    Daveowen, although the 42" will initially look very big, you will find you get used to it very quickly. I would definitely go for 42" at 9 feet viewing distance. If stand mounting though, make sure on measurements first.
  9. orange66
    orange66
    42" on a wall looks fine. But 42" on a cab stand, it is a room dominating monster, be warned!
  10. RockSteddie
    RockSteddie
    Mar 26, 2005
    1,137
    +137
    I also bought a 37" plasma and must admit now that I wish I went for the 42" instead. When I first started to watch it I thought wow this is big but as time goes on you soon get used to the size and this is from about 6' away. If you can afford it and have the room, definitely go for a 42" model.
  11. Lionheart
    Lionheart
    I have mine with a cabinet and it doesnt dominate at all (and its not a huge room)...it looks just fine......and the added bonus that the cabinet can hold alot of kit....I have a centre speaker, telewest box, a ps2 and xbox all happily housed in mine
  12. rowlandhills
    rowlandhills
    Feb 9, 2005
    427
    Baldock
    +18
    My wife had always said that we didn't really need a bigger tele than our current 28" CRT...until this week, when I cut some newspaper to size and stuck it up on the wall. She agreed that the 42" was a much better fit for the room than the 37"! :)
    Now just got to sort out finance, sell the old tele etc....
    Might be worthwhile making a mockup yourself (held up with masking tape or blue tack) to see the difference easily, from your normal viewing position.
  13. Jim_Fear
    Jim_Fear
    May 17, 2005
    1,801
    Caterham
    +59
    The 42" PV500 looks small compared to the 42" plasma we have in our living room, its really strange I know and I cant explain why, it just looks smaller to the eye
  14. Baron Von Doom
    Baron Von Doom
    Mar 15, 2005
    1,569
    worthing
    +176
    go for a 42". i got a 37" and im now saving for a 42".
  15. dave owen
    dave owen
    Dec 8, 2002
    72
    Thanks for all your replies. We decided on the 42 but the salesman said get a 37 because a 42 would be too big, ironically he had no 37's in stock. However we value your advice on here more so despite him throwing doubt in we will stick with a 42 based on your advices.
  16. WillC
    WillC
    The salesman told you to get a smaller cheaper model? That's unheard of! :D
  17. Ender4000
    Ender4000
    Dave, did you get the 42 inch? Are you happy with it?
