37" LCD options?
Discussion in 'LCD & LED LCD TVs' started by asm495, Dec 8, 2004.
  1. asm495
    asm495
    Oct 22, 2004
    49
    I had placed an order for a LC37GA3E but thanks to Sharp's foresight that has now all fallen through. My question is now, what options are there for 37" LCD screens.
    What I am looking for is:
    - True 16:9 pixel format (e.g. 1366x768 rather than 1280x768)
    - DVI input allowing me to send a pixel perfect signal from my PC
    - Max price £2,500
    Although there may not be anything out there which does that currently is there anything coming on the horizon that will?
    Any ideas much appreciated.
  2. pacman
    pacman
    Nov 22, 2004
    37
    If you can stretch to £2750 the Philips 37" 9986 is absolutely stunning!
  3. asm495
    asm495
    Oct 22, 2004
    49
    Can you output 1366x768 from a PC via DVI with that? Is the price likely to drop at all in the New Year?
  4. Xelon
    Xelon
    Nov 16, 2004
    391
    +53
    Have the same problem, nearly ordered the GA3 37" from Empire Direct for under 2K, no more available it seems, don't want the GA5 (no DVI) would like all the features mentioned in the first post, plus HDMI input, maybe Tosh will bring a 37" to the table? Just got to play the waiting game for now, which will mean more for less eventually I hope.
    Of course by next year I'm sure a 32/37" panel will be released with a 1920 x 1080 res for 1080i/p HDTV.
  5. pacman
    pacman
    Nov 22, 2004
    37
    RE:
    "Can you output 1366x768 from a PC via DVI with that? Is the price likely to drop at all in the New Year?"
    Another member - Alan D - pointed out to me that the Philips will only give 1024 x 768 from a PC through DVI. However, a few pixels each side is no real problem for me on an otherwise 'stunning' display.
    I expect the price will fall, although how fast who can tell?
    I too could have waited, but there will always be something else to hang on for and I wanted something now!
    Regards
  6. andya
    andya
    Oct 25, 2002
    2,391
    48
    manchester
    +26
    i hear that panasonic are bringing a 37inch lcd out next year that will have hdmi.and sharp have told me they are still producing the 37inch g series panels
  7. asm495
    asm495
    Oct 22, 2004
    49
    Seems to me that there is little choice out there unfortunately. Panasonic panels so far have also just been 1280x768 and I'm not sure if they are likely to change away from that.
  8. jgrg
    jgrg
    Oct 19, 2004
    547
    28
    Cambridge
    +33
    You should be able to get a LC37GA4E (side mounted speakers) - I think they are continuing to make it, with only the GA3Es being replaced with GA5Es. It is also possible that the LC37GA5E has DVI, but the LC32GA5E doesn't.
    James
  9. asm495
    asm495
    Oct 22, 2004
    49
    Everything that I've heard says that the GA4E has been discontinued too - what makes you think that it hasn't been?
  10. andya
    andya
    Oct 25, 2002
    2,391
    48
    manchester
    +26
    i emaile sharp and they told me the g series 4 are continued but the 3 are discontinued
  11. Sluggster
    Sluggster
    Nov 30, 2004
    524
    28
    Fareham, Hampshire
    +31
    What about the Loewe Xelos? That's about 3k I believe. I saw the 37 Spheros in action today and it looked pretty impressive. May require a few months extra saving though.
    Sluggster
