37" HDTV??
Discussion in 'Televisions' started by chris_huh, Feb 7, 2005.
  1. chris_huh
    chris_huh
    Mar 28, 2004
    73
    London
    I am looking at getting a new tv soon since i will be receiving some credit from Comet since my 36ZP38 has a wonky button (dunno why they can't fix, the tv works fine). I am looking for a screen no bigger than about 37" and preferably be a HDTV. I don't know if these even exist, looking around i found a few which claimed to be hdtv's until i look at the specs and then i get confused.
    Are there any hdtv's of this size?
  2. stlic
    stlic
    Feb 17, 2004
    733
    +15
    Wouldn't the Philips 37PF9986 fits your requirments. Comes with a HDCP DVI-I and 1366 x 768p res. Or are you looking for 1024i?
  3. Ricardfred
    Ricardfred
    Feb 5, 2004
    83
    Yes the Philips 37PF9986 would be the perfect choice..of course Im biased as I have one. Great tv. Theres a thread on the LCD TVs forum. Just do a search for HDTV LCD's.
  4. richjthorpe
    richjthorpe
    Aug 2, 2004
    2,026
    41
    dat london
    +13
    The Sharp 37GA4E and 37GA3E have the same resolution as the Philips.
  5. gilesm
    gilesm
    Aug 29, 2002
    179
    UK
    Chris
    Could take a look at Loewe Spheros 37 HD/DR+ and the Xelos 37 (also think they now do them in 32 and 26 inch as well). Both HD ready, both have HDCP over DVI and are high definition 1366 * 768.
  6. hornydragon
    hornydragon
    Dec 19, 2001
    28,293
    +1,215
    for HDTV at 37" it would have to be an LCD mate most with exception of Sharp GA5 are fully HDTV compliant (has no DVi//HDMI as far as i can see) Phillips and sharp are both very good i prefer Sharps.....Especially the GD1E sets
