37-40" smart tv, freeview hd. Is this possible?
Discussion in 'What Is The Best TV For You?' started by Hockeynut, Feb 13, 2014.
  1. Hockeynut
    Hockeynut
    Jul 9, 2007
    155
    Nottingham
    +4
    I want to ditch my sky subscription and so a viable freeview hd smart tv seems the order of the day. When I've previously considered this it has always. Been with needing to get a freeview box to record. But I've recently heard that the newer tv's can record to a drive directly.
    Do I need to get a twin tuner tv to be able to record something when I'm watching something else? Is that even possible straight from a tv?
    Sound isn't a high priority, as I have a amp etc.
    I don't need wireless, but would like a network a network connection, as I want the apps available for netflix, iplayer, on demand, etc.
    Usually I prefer samsungs. Is the above correct and is it possible for between around £400-550?
    Any advice appreciate, as it's been a long time since I've looked for a new tv.
    Thanks.
  2. vickster
    vickster
    Jun 25, 2006
    17,284
    +1,921
    Most TVs only allow you to watch and record the same channel. Some do have dual tuners, but at the top end so out of your budget I would think
    Dual tuner PVR would be more useful
    Find the TV with the apps you want, Samsung tend to be better equipped
