N
nijac
I'm looking for either a 37" or 40" LCD - I'm bound by a max cabinet width of 100cm, which rules out anything bigger than 40". Pity, because it rules out the Sharp LC42XD1E, which in the demos I've seen had the best LCD picture (and comes highly recommended from two work colleagues). I've also seen some good demos of the Samsung R87s. But are there alternatives to the Samsung 37/40 that I should consider - eg the Sharp LC37XD1E, which from RS falls into my budget range (but haven't found one on display)? Any others worth a look?
Sources are Sky+ box and DVD (although I'll be changing this to an upscaling model at the same time). I'm in no particular hurry to rush out and buy the first thing I see, so grateful for any advice.
