37” plasma dilemma
Discussion in 'Plasma TVs' started by Chris The Ninja, Jun 21, 2005.
  1. Chris The Ninja
    Chris The Ninja
    Mar 10, 2005
    176
    +3
    I need your help. I am looking for a 37” wall mount plasma for under £1500. I was set to buy the Panasonic TH37PE50WAL which I found for £1369, I like the built in freeview decoder but I am put off by the lack of HD. I can not stretch my budget to £1800 for the PV500. Then I considered the Hitachi 37PD5200, but after reading some posts in here I am not sure about that one either, plus I have not found it for sale under £1500. I am starting to go around in circles and reading too much. Is HD important? I don’t have Sky but I do enjoy movies and games, and i will be the first to buy a PS3. The ability to plug in a computer would be nice, but the most important requirement has to be picture quality for both freeview and DVD’s right now. Does anyone know where I can buy a 37PV500 for under £1500, I’m joking. What would you suggest. :suicide:
