36ZP48 Service Mode List of Options
Discussion in 'Televisions' started by L00py^, Jan 14, 2005.
  1. L00py^
    L00py^
    Sep 23, 2004
    129
    Can someone please post a link to the previous post listed how you get in the service mode and what options you can change again please. Can't remember in which post I read it in last week.
  2. Respighi
    Respighi
    Dec 9, 2004
    30
    Hi there. Fondue posted this:
    "Service menu is accessed by using the remote, pressing mute THEN pressing and holding mute WHILE pressing the menu button ON THE TV.
    To get the pattern up, press the SOURCE INPUT button several times (it'll cycle a red, a blue and a green screen before getting to the grid)."
    here: http://www.avforums.com/forums/showthread.php?t=147573&page=21&pp=15&highlight=toshiba+service+menu (post 306)
    You can cycle through different settings with the programme up and down buttons, and alter the values with the volume (left and right) buttons. But I don't know what they all do.
    Can somone do me a favour and tell me what the initial setting for RCUT is please? I might have changed mine by accident and I want to make sure it's back to the default setting. Currently it reads:
    RCUT 0410H
    40H 01000000B
    Many thanks.
  3. Sarnaget
    Sarnaget
    Dec 31, 2004
    33
    Mine reads
    RCUT 0410H
    51H 01010001B
    Not sure if that helps but it seems a way off yours, I can't see you accidently having altered it by so much... !
    Ryan
  4. Respighi
    Respighi
    Dec 9, 2004
    30
    Thanks Sarnaget. I think you're right; i don't think I altered mine after all.
    But I have just had a good fiddle with the other settings and managed to correct some geometry problems I was having before. What a great TV!
