36zp48 packages
Discussion in 'Televisions' started by TWOFISH, Nov 26, 2004.
  1. TWOFISH
    TWOFISH
    Nov 24, 2004
    19
    3
    Whist searching for best prices I noticed some internet retailers offering home theatre packages with the Tosh 36zp48. What is the reasoning behind this, I was under the impression front and rear speakers are supplied with this model with 5.1 digital built in to the tv. I am not very clued up re. surroud tv so would appreciate some advice
  2. allengn
    allengn
    Sep 6, 2004
    104
    Sutton Coldfield
    You are correct, it does have Dolby Digital built-in, and Toshiba do supply 4 surround speakers (the sub is in the back of the TV).
    However, whilst the sound from these is good, and would certanly be an improvement over a standard stereo set-up, it only outputs around 10w per channel, and does not have the clarity, depth of sound etc. that a full home cinema system with dedicated amp etc. can provide.
    I have the 32ZP48, and my main reason for purchase was the very slim frame and excellent picture. When playing DVD's on prog scan, with sound through a dedicated amp and decent speakers, the results are outstanding.
