36zp48 - No RGB.....just composite
andrewg500
Joined
Oct 15, 2005
Messages
4
Reaction score
Points
Age
55
Location
Ormskirk
I have just got a replacement 36zp48 for one that had a black line down the centre when initially switched on. The replacement does not receive RGB from DVD or Sky on Ext 1 & 2. These are both RGB inputs and worked fine on the first delivered set. The picture on both DVD & Sky shows that annoying and unwatchable interference above words and lines etc.
I do not know if the wrong scarts have been fitted or more likely the TV is not realising that it is receiving an RGB signal.
Having returned one of these sets I am angry and reluctant to put another beast back in it's box.
I would appreciate any help you guys can offer.
Andrew
Andrew
Maybe in the process of reconnecting the SET your set-top box or DVD switched back to composite (if you unplugg'd them from mains or something)...maybe TV itself needs telling that it should receive RGB via SCART like some old Sonys...sorry for the clumsy comparison... :D
Thanks Kalos.....I have checked and both DVD & Sky have RGB settings intact and I do not think there is an option on the set-up of the 36zp48 to enable or recognise a RGB signal....I think it is meant to be clever enough to detect the appropriate signal.
Andrew
Andrew
So no luck, huh??? :rolleyes:
i suffer the exact same problem but trying to ignore it, the sky programme banner looks poor for example, no idea how to cure it :confused:
I had a job last week with the same initial RGB problem. There was no RGB from the dvd, sky to customers goodmans plasma. At first glance it would seem logical that the plasma was at fault, but it turned out the dvd was faulty and the sky box just needed a reset to get the RGB back.
At least worth a try first.
Tried the obvious kind of things already. I will get the supplier to get an engineer out to it. I wouldn't normally hesitate in requesting a replacement, but after the hassle of getting the preivous 12 stone monster back in its box and then the most ignorant foul-mouthed delivery monkeys in the world, I just cannot face up to it. So it the engineer or money back....and I go back to my 32" "on it's way out" Toshiba.
Looks like it has to go back. I dont know of a tv nowadays that doesnt enable signal switching on Scart inputs.
Providing the same scarts and settings on the boxes are intact, it must be the Tosh. No doubt its a full 21 pinned scart cable you have.
Luckily I have had no problems with this tv at all.
The BIG PROBLEM With Your Home AV System EXPLAINED
Back
