36ZP18P Sound Problem
Discussion in 'General TV Discussions Forum' started by Matt M, Jan 6, 2003.
  1. Matt M
    Matt M
    Fairly regularly my set rattles when reproducing what can probably be best described as 'harsh'/low sounds.
    I have tinkered with sound and bass options and neither seems to make any difference. I think it is the actual signal rather than my TV settings that is causing the problem.
    Is there anything I can do about this? The Tosh helpline suggested very unhelpfully that 'perhaps the TV is not attached to its stand correctly'
    Has anybody else experienced this problem or do I need to get a technician to visit?
    Any help would be most appreciated.
    Matt
  2. popester_uk
    popester_uk
    Dec 10, 2002
    316
    Brighton, East Sussex
    +9
    This may sound a bit off the wall, but when i spoke to one of my local independant retailers regarding this set, he visibly whitened and said he'd had many many problems with the clips holding the tube in the chassis/case.
    Apparently they're a special design due to the thin case and had a habit of breaking. maybe this is what is causing your rattle?
    Kelvin
