36ZP18 Sides brighter than middle - anyone a way round this?
Discussion in 'General TV Discussions Forum' started by Markster, Nov 9, 2001.
  1. Markster
    Markster
    This problem is really anoying me.
    I have noticed that both the right and left sides a far brighter than the middle.
    On any dark scenes this is very apparant. The only way i can get rid of this is to turn my brightness setting down to about 39 which then makes the picture way to dark.
    Has anyone found a way around this with other settings or had an engineer fix this somehow?.
    I am reluctant to return my set in case i get another one with even more problems!!.
    TIA
    ps. do the m,1,2,3 setting actually do anything special or are they just basic presets for brightness, contrast etc?
  2. dts borg
    dts borg
    Sep 5, 2001
    579
    Hornchurch
    +8
    I have a thread going ALL TOSHIBA 36 & 32 Owners .
    Please add your faults here,as I hope to speak With TOSHIBA next week.
    Thanks Keith
    Will keep you posted Re: Tosh faults
  3. Doubledoom
    Doubledoom
    1,2 and 3 are presets. The M setting is your chosen settings. IF you choose 1 or 2 and then amend them, Dynamic contrast remains on. If you choose 3 and amend the settings, Dynamic contrast will be turned off
