36zp18 new batch?
Discussion in 'General TV Discussions Forum' started by hutchys, Feb 18, 2002.
  1. hutchys
    hutchys
    Feb 4, 2002
    135
    16
    hi,
    I was considering buying on of these tv's could anyone tell me if the problems reported have been solved in the last couple of months or is it still best to wait a few more months yet to purchase,and see if they have sorted out most problems reported with the new batch?that is filtering through
    tia
    jim
  2. m@rk
    [email protected]
    Jan 3, 2002
    1,222
    83
    Lincolnshire
    +374
    Depends on if you are talking about the features or the faults.
    If you mean the bright edges with darker vertical bars then these are a 'feature' of the tube used and the new version will be using EXACTLY the same tube.
    The new batch (the famous q model) have the following changes:
    Updated tuner to allow for different broadcast standards across europe.
    A new teletext chip
    A new remote
    And thats it.
  3. hutchys
    hutchys
    Feb 4, 2002
    135
    16
    yes i was talking about the faults so these will/could still be evident in the new tv's then?
    thanks
    jim
  4. Jimbob
    Jimbob
    Frankly I would wait and see
    They are hardly like to list things like...
    '*Fixes annoying light bands that existed on previous models '
    ...on the new Q models specification.
    That would be like admitting there was a problem!
    I would imagine the fixes will be there but they wont be mentioned anywhere. Time will tell.
  5. Markster
    Markster
    Hutchys
    The only faulty that has been fixed is the teletext one.
    The rest of the issues mentioned are not faults.
    The lighter sides, dark patches, hite glaring etc are features of the set; other issues mentioned like some people experiencing power hum etc are just on some sets, you can get this with any manufacturer of Tv, sony, philips etc,it is not a fault with a particular model it is just fact you will get variations form a production line environment, if yours is a particularly loud one you just have to arrange a replacement.
    There seems to be a huge expectation of the Q models.
    As has been mentioned in other threads there is no real difference between the Q model and previous versions.
