36ZD26P stand
Discussion in 'Televisions' started by common, Jan 31, 2003.
  1. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    simple possibly silly question, but I've only seem images on the net
    How does the stand work ? does it actually have shelfs behind the 'cloth' grill ?
  2. Yugo1
    Yugo1
    Already posted a reply about this somewhere...
    The top opens upwards and the bottom down wards. The covers to the flaps are glass with a dull silver covers (with loads of little holes not through the glass)
    Looks very nice.
    Yugo1
  3. common
    common
    Mar 5, 2001
    1,384
    41
    Oxford UK
    +8
    thanks pal
  4. juboy
    juboy
    Those 'covers' are just thin strips of self adhesive, perforated plastic. If you move the TV a couple of times you'll see how easily they come off :rolleyes:
    BTW, don't expect to a decent sized AV amp in the shelf space/case, mine didn't fit with cables connected and I had to buy a second stand for it.
    The stand does look nice but it's not up to much practicality wise.
  5. langas2003
    langas2003
    Does anyone know whether this TV is any good...(I would like to know if its excellent to be more precise)?
    I am thinking of buying one from RGB Direct for £1270...this is the cheapest anywhere!
