36zd26
Discussion in 'General TV Discussions Forum' started by Big fellow, Jan 23, 2003.
  1. Big fellow
    Big fellow
    Is there anyone who can help me out?
    I want to know the original service settings for a toshiba 36zd26 tv. I had curving lines at the sides of the tv, i tried to cure it in the service setting but have made matters worse. Can anyone please help me out as i'm stuck.
  2. bibooo
    bibooo
    Aug 15, 2002
    227
    Earth
    +11
    Big Fellow,
    I'm afraid you should have written down all service menu settings before "tinkering" as there are no standard settings.
    The difference between two identical models can vary greatly; you could replicate the service menu settings of a ZD with "perfect" geometry and achieve even worse results.
    "Fudging" around in the service/designer menus will also invalidate your warranty.
    I would concentrate on the PARA, CNR, HSC and CPAR parameters to get rid of the curved lines at the sides; If you haven't already, take a look here for a rough guide.
    Good Luck.
