36PF10 Help!!!
Discussion in 'General TV Discussions Forum' started by luckysharma, Oct 31, 2001.
  1. luckysharma
    luckysharma
    I used the service mode to re-frame my picture, which is now near perfect, however since doing this and saving the settings, the sound is now abit strange ( annoying really). The sound is being produced with very high pitches ( Trebble) being exagerated. Does anybody have any idea how to correct this or know how to do a reset on the TV. The service mode instructions that I found floating around on this site only allows you to modify and save the frame settings. I have had my TV reset once along time back when it was under warranty by a service engineer. But he didn't show me how.
    Any advice or informtion would be greatly appriciated.
    :confused:
  2. William
    William
    Sep 4, 2000
    60
    Shropshire
    Apologies if this is stating the obvious, but have you changed the treble and bass controls back to their normal positions ?. You need treble at max and bass at min to get into the service menu and I have on more than one occasion forgotten to put them back afterwards.
    William
  3. William
    William
    Sep 4, 2000
    60
    Shropshire
    Sorry I realise that the setting to get into the menu is bass to max and treble to min ie the other way round. Obviously this doesn't explain your particular problem of too much treble.
    William
