36NX200 query
Discussion in 'Televisions' started by KANU25, Mar 15, 2003.
  1. KANU25
    KANU25
    I've had this TV for for 2 weeks and all I can say is... its superb!!!
    All sports, sky, dvd, humax, drc 50, drc100 - all brilliant picture.
    But I have got a couple of issues(if not solved then I'm not worried but just wandering if it can be sorted):
    1. The picture is very very slightly arched at the top - you can hardly notice it unless you go close up - but can this be straightened???
    2. A very small glitch everytime I go into Teletext - its doesn't bother me but just wandering if anyone else had this problem??
    3.One time the green led light blinked red a few times constantly - didn't know what it was but the sony guy told me it was probably interference from something he told me to turn it off and back on - and it was OK - anyone else had same prob??
  2. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    What is the teletext bug - is it the BBCi Cloud display problem?
  3. KANU25
    KANU25
    not sure what the cloud problem is. But everytime I go into teletext - it glitches
  4. MartinImber
    MartinImber
    Apr 5, 2001
    3,851
    71
    Worcester
    +21
    The first gen problem is that BBCi weather clouds take ages to draw
