36FS70 Tweaks
Discussion in 'General TV Discussions Forum' started by Kevin Gilmour, Nov 28, 2000.
  1. Kevin Gilmour
    Kevin Gilmour
    As you might have gathered from some of my other posts, I'm extremely happy with this set.
    However, wega being wega, there are a few geometry tweaks I would like to perform.
    No problem getting into the service menu's except for the one I need - deflection.
    This menu is so distorted that you can't navigate through the adjustment option list !
    Anyone come across this and been able to overcome it ?
    Kev
  2. TM
    TM
    I get exactly the same result on my 36FS70. It is only the defection menu that is affected this way. I did wonder whether using an empty broadcast channel or an AV channel with nothing connected to it might help as it could be a 'genlock' type issue, the only problem is I then can't see what affect my changes are having!
    Mark
  3. michael347
    michael347
    Try making sure that PAP is off and put the set into DRC 100 mode , thise should make the deflection sub menu stable, but a word of warning, playing with the service settings is dangerous for your set, copy all original values first, default values are not necessarily original values.
    Mark[/B][/QUOTE]
  4. Kevin Gilmour
    Kevin Gilmour
    That did the trick
