360 Wireless adaptor...MAC address?
Discussion in 'Xbox Forums' started by leamspaceman, Aug 4, 2006.
  1. leamspaceman
    leamspaceman
    Jun 22, 2004
    7,850
    +4,320
    Just set up my 360 and I've got a wireless adaptor.
    I have 'MAC address filtering' set up on my wireless network. So, I need to enter the MAC address of the 360 wireless adaptor into my wireless modem...I think?
    I had to do it with my PSP so surely need to do the same? How do I get the MAC address of the 360 wireless adaptor?
    Thanks.
  2. windie
    windie
    Jul 8, 2005
    367
    28
    +26
    I don't use one myself, I have a netgear thingy majig. Normally all network cards have it printed on the device. failing that I can only suggest looking in the network settings on the sytem tab. Or plugging it into a PC and checking the settings from there, surely XP will recognise it as a usb network adaptor.
    IPconfig /all from a dos prompt. Look for the new adapter.
  3. rimmep1
    rimmep1
    Jun 19, 2004
    213
    28
    +40
    The Wireless adaptor shares its MAC address with the Ethernet socket on the console. Strange, but true.
    It'll either tell you in what the MAC is in Network Settings on the console or alternatively, connect it via Ethernet temporarily, your router should tell you.
  4. Bigpants2k
    Bigpants2k
    Jan 8, 2003
    219
    Bracknell
    +12
    go to the system blade, then click the network settings tab. then edit settings, then additional settings and then click on the advanced settings box and there is your MAC addy
  5. leamspaceman
    leamspaceman
    Jun 22, 2004
    7,850
    +4,320
    Hey guys...thanks for your speedy replies.
    So...do I only need to enter ONE MAC address, the one I've been directed to above?
    Don't I also need to enter a MAC address for the wireless adaptor itself?
    Many thanks.
  6. Bigpants2k
    Bigpants2k
    Jan 8, 2003
    219
    Bracknell
    +12
    the wireless adapter has the same mac addy as the ethernet port.
    so the one you can see on the screen is the one you need to put into your router
  7. leamspaceman
    leamspaceman
    Jun 22, 2004
    7,850
    +4,320
    Cheers FFF...much appreciated. Thank you:clap: :clap: :clap:
