R
rickmus
I've been trying to get my PowerlIte Home Cinema 1080 to be happy with my 360 VGA resolution at 1920 x 1080. The image will be cropped off both horizontally and vertically, as if zoomed in by 15%. I've had no luck with any projector settings to get it to display the image properly. I've had a computer hooked up to the vga displaying 1920x1080 without any issues at all. I can switch back and forth and watch the computer be just fine while the 360 will show the zoomed in image. If I select the next lower resolution that is still wide screen for the 360, then everything is fine.
Any ideas on how to get 1080 to be happy?
