360 - Streaming DVDs Query
Discussion in 'Xbox Forums' started by Buckster, Dec 23, 2006.
  1. Buckster
    Buckster
    May 21, 2001
    7,247
    103
    UK
    +370
    WE have a son that tends to destroy DVDs ...
    therefore I have quite a lot of our cartoon DVDs backed up on my PC.
    is there anyway - to play these direct from the PC streamed onto the 360 ? with full 5.1 etc ?
    thanks, Mark.
  2. Waynej
    Waynej
    Oct 4, 2004
    8,067
    Wales
    +1,316
    Yes, assuming your PC and 360 are on the same network then you should have no problems. I'm not sure about 5.1 but if you transferred them to your PC by way of a TV capture card and just so happened to save them in .WMV format then they'll play perfectly fine streaming straight to the 360 from the PC. If they are in another file format then having a Windows Media Centre PC would be your best bet, though there are currently ways using different software and such to stream different file formats to the 360 from an XP machine. I have actually tried this myself but with little success.
  3. peterc_drs
    peterc_drs
    kinda on topic here.....
    i'm interested in streaming dvd's to the 360, so i can play my non region 2 disks on the 360's media centre, i quick web search didn't show up much.... any one have any expeience with this...?
  4. dunks517
    dunks517
    May 22, 2005
    4,005
    Orbiting Bono's Ego...
    +516
  5. LCR_Dave
    LCR_Dave
    Jun 27, 2005
    1,441
    +74
    sod all that stuff, just rip the dvd onto the pc creating one big .vob file, rename it to .mpg and it will play fine but with no menus, the xbox 360 will not play ripped dvds any other way unless it is converted to another format,
    hope this helps
  6. peterc_drs
    peterc_drs
    yea i kinda figured that would be the case, not a real time option though, but thanks for the sugestions
  7. Buckster
    Buckster
    May 21, 2001
    7,247
    103
    UK
    +370
    thanks for the help guys.
    one last question - with the Premium version - you get component out yes - do you also get optical out ? Or do you have to buy the Component + Optical cable ?
    thanks, Mark.
  8. gseh
    gseh
    Jan 21, 2004
    37
    Glasgow
    How do you go about creating one big VOB file?
    I'm currently using DVD Shrink and that created an audio and video TS folder which I then play thru my PC.
    What program do you use to go down the VOB route?
  9. peterc_drs
    peterc_drs
    the permium i got, included the component lead which has optical out on it, but also has 2 channel analogue
  10. campbellm
    campbellm
    Quick question - I thought to stream video from your PC you have to be running Windows Media Center on your PC? I've currently got a laptop with Lost Series 2 on that I'd love to run through my 360 into my TV? Any thoughts?
  11. LCR_Dave
    LCR_Dave
    Jun 27, 2005
    1,441
    +74
    dvd decriptor but search google on where to get it as i may be on the line disscussing it and what it does! on there there is a setting to create 1 big vob, only problem ive ever had doing it that way is it pauses in the middle just ff 2 seconds and its fine again,
    hope that helps
    also search for a program called my movies, its an add on for media centre xp
