Can anybody help, when launching my 360 it cannot pick up the music in my music on MCE on my laptop, it can see the HD clips fine, is there a refresh button etc i need to use
Push the is it `info' or `more' button (can't remember which one) while in the music section on MCE on xbox360, and select the `add folders' option from the pop up menu. This will then allow the 360 to know what folders it should access on your pc.
You need to correctly set up MCE on both the pc and the 360 before it will show the files/folders you want to access.
