360 not auto signing in to Live
Discussion in 'Xbox Forums' started by dannius, Sep 16, 2007.
  1. dannius
    dannius
    Feb 12, 2006
    3,417
    +356
    This is probably something obvious, but my premium always used to auto sign me in to Xbox Live when I turned it on. My new Elite doesn't for some reason, it auto signs me in to my profile, but I have to manually sign in to Live.
    Any ideas why?
  2. Codehead
    Codehead
    Jan 20, 2007
    5,928
    Hanging around the goal in Rocket League
    +1,158
    Do you have a Wireless network adaptor? If so you won't get auto-sign on to XBL if there's a disk in the tray at boot.
    This started happening after the last dashboard update.
  3. johny1980
    johny1980
    Aug 30, 2006
    2,455
    83
    Aberdeen
    +339
    it wont aut-sign me in either and im wired ?
  4. The Hotspur
    The Hotspur
    Feb 12, 2007
    701
    28
    +52
    i had exactly the same problem after switching to my elite. using wireless network adapter, disk (gow) in tray but set to start up to dash, my profile would sign in but not sign into live.
    then, yesterday, it started signing into live albeit after a 10-15 second delay after profile signs in. strange.
  5. Br00n
    Br00n
    May 3, 2006
    1,412
    48
    Bonnyrigg
    +82
    was havving the same issue after getting my box back from repair. i sorted it by changing auto log in to disable, back to dash, shutdown, bootup, change to enabled.
    :D
  6. dannius
    dannius
    Feb 12, 2006
    3,417
    +356
    Yeah using the wireless adaptor. It doesn't really bother me, just thought it was weird that's all.
    Cheers for your input chaps, i'll have a play but not bothered if I can't figure it out.
  7. sdb123
    sdb123
    May 17, 2005
    18,183
    2
    Rushden, Northants
    +2,255
    This happens to me too (on my Elite)...strange.
  8. johny1980
    johny1980
    Aug 30, 2006
    2,455
    83
    Aberdeen
    +339
    auto log to disable where ? i cant find anything ?
  9. Br00n
    Br00n
    May 3, 2006
    1,412
    48
    Bonnyrigg
    +82
    log in to live, click on your gamercard and the option is in there.
